I have problem with wifi with my xperia mini when i connect it turn of my router(tp link wr741nd). i sent my phone to local sony dealer(under warranty)and they just downgrade to ginger bread.
Can you tell me how to fix to use ics because i dont want to use gb i bought this phone beacuse it says that they can use ics.
I try everything update my router firmware update from sonny pc sotware,try to put router in all wi fi modes.
It just cost me more money because i cant use my wi fi and need to use mobile internet that is expensive.
Sorry for my bad english hope you have some solution for this problem.Thx
Check this thread, all information you should need:http://talk.sonymobile.com/message/154244#154244
I already did all that and works great on other phones but not mine, as i said on ginger bread working great when i update its working in couple minutes and then just turn off my wlan card on router and need to tunn on and off to work again untill they break up again and its practically usseles.
I try on other routers it same thing except huawei routers.
I have all updated to latest version
If none of the things mentioned in the thread above works, you should send in the phone to a service center for repair as it seems to something wrong with your phone. Contact your local Xperia Support for more information:
