I got random touches when i use my acro with wet fingers. I try to dry it with a towel but the screen still move randomly. I need to reboot my phone to work properly again. I think my phone dont have wet finger tracking feature. Yes its water proof but i cant use it when the screen goes wet. What shoul i do?
I think that you should try to update or reinstall the phone software if you're running on the latest version and check if the problem still remains.
If it does this might need to checked at a repair center.
http://www.sonymobile.com/global-en/support/contact-us/contact-info/
