W595 redial problem
W595 redial problem
my phone has decided to change setting somehow
and i dont know how to cure it
after ive called someone and i want to call them back
normally i would press the redial button
but each time i do, it calls another number which i spoke to days ago
even though ive made many calls since
what setting has been changed
help
I think you cant do anything with the settings; it's probbly a software malfnction and a master reset should fix it. so give it a try.
