W205 help/advice
W205 help/advice
I have bought a W205 a couple of months ago and i have question to other W205 owners,
Do you have problems with the Battery performance?
Mine only lasts about 48 hours with about 10 minutes talk !!
Is there any solution? a battery was charged as said on the instructions and i have charged it a few cycles and the performance is still bad.
Thank you for your help in advance.
2 REPLIES 2
Yeah bro...Even i face the same problem..I regret on buying this phone...I charged the battery fully for the first and still i can't use it....
I am using w205 since july 2009...battery life was not at all a problem for me although I regularly talked over 4 hours per day and listened to music for another 2 to 3 hours, the stand by battery life was over two days even after all these! it's only after my phone got fried due to my fault and I had to change the mainboard inside, when I got it back frmo the service centre, the phone's battery does not last more than a day...but overall with the service and after service I got at this price, I would say it's a good buy !
