hi
i don't know why one of the theme in my xperia sp cleaned !how i can find or download it ?
You might have disabled it,go to settings-apps-all and look for it.
no i didn't disable, when i update me xperia that theme was applied on my phone then when i change it to another theme i miss that them !!
Did you update?
yes i update my xperia sp to 4.3
Think so. the update swiped the theme..just try resetting the device....it may help..or reinstall the update..
Or the theme is not there anymore,not because of being deleted but because it is not there in the 4.3.
Mr alexdon ,that theme was after update i lost it recently when i change theme
i don't think so , but how i can reinstall the update or return to the orginal setting ?
