Syncing and wifi connection
Just had to reset phone due to issues and guess what i get different one this time.
My sync wont work with sony soft ware due to email not existing to a current account  or pass word is wrong, Niether are due to I can log in via my pc no problems
My second new issue since the so called up date is my wifi keep looseing it connection and unable to connect again even though the passwords not change and the single strength still the same.
My point is are othe people having similar issue and is sony aware and will the soft ware update pos when ever they are going IF going to happen pos sort this out.
sync doesn't work for me over wifi - have you tried connecting using your network?
If you fill in all the address, URL and birthday fields on the web site sync will fail - just use name, email addresses and phone numbers and see if it works then
