Sola endless problems
maga
Having serious problems with Wifi and Gps since the beginning (Nov 2012).
I tried ALL possible solutions including sending the phone to the technical service where apparently they changed the mother board (with no change).
Simultaneously, I have an Xperia U working perfectly under the same conditions.
-Activating Wifi causes boot loop (but not always) Only many hours later the phone can be restarted.
-Gps   works occasionally (while Xperia U is fine).
I have tried all possible solutions like repairing with SUS and restoring factory settings.
DEFINETLY IS A FIRMWARE PROBLEM since Gps and Wifi sometimes works and Xperia U also works perfect. (both with ICS)
Sending again the phone to the technical service is not a solution.
Please Sony brains. Do Something.
3 REPLIES 3
profile.country.PH.title
MarlonUk1
how about trying other roms, I know it will void your warranty but if its the crappy firmware thats causing this, your off to find a good one elsewhere.
maga
Some recomended link?
MarlonUk1
https://sites.google.com/site/projectfreexperia/
try going to XDA forums for more information
