so right now i am in ICS but when i hold the power button and select silent mode or vibrate the phone still rings when someone text or call me..but when i just press the volume button down to vibrate or silent button it works.. anyone had the same problem?...
When you select the options from the power button method do the icons next to the signal bar change to show this selection? Could you also confirm which model of phone you are using.
What do you think about this forum? Let us know by doing this short survey
yah icons change when i do that even it is turned to silent mode the phone still rings...I am using Xperia Go/Sony ST27i..
I would suggest a software repair on the phone. This can be done via the PC Companion.
How sir?..
i have the same problem... whn i took it to the shop. the shop keeper said that i need to change some parts... what do you think about this matter??? pls explain...
I am having Xperia V. I guess when i upgraded to latest firmware for Jelly Bean only after that I am now experiencing this problem.
When i set my phone either to Vibrate/Ring, it still receives the call and rings with full volume which i very irritating. The very purpose of Silent/Vibrate is spoilt. I am very annoyed in my meeting room, etc
Sony, u told we can do by software repair using software companion. Please describe in detail or please provide a solution ASAP.
Thanks,
Srini
Please describe in detail. Facing same issue in Xperia V after upgrade to JB
I too, have the same problem. plus, the 3 main keys (back, home, and options) arent so responsive. I sometimes had to touch it again and again to respond. My phone is Xperia SL
The following link would help you with this: http://talk.sonymobile.com/thread/54636
