problems with pc companion
fer2146
Greetings:
I communicate because I have problems with PC companion, and not recent, while my xperia connect I get a message saying: THE APPLICATION NOT INSTALLED LATER TRY and this is already more than a month ago and that is with all users , would be so kind as to tell me what is the problem with SONY?
2 REPLIES 2
Uninstall PCC > restart your PC > install both PCC and SUS > restart your PC > disable your firewall and antivirus > run either or
Update Service (SUS)
PC Companion (PCC)
coolhz
Make sure you have an active Internet connection while using PC Companion, as when you click on any of its app for the first time it downloads a 1 MB or  Mb file of it and then only the same is operational.
