Problems using head phones on Xperia tablet
Christian88
Whenever I plug in head phones and run any music or videos the sounds comes out through the device speakers. I have to press play first then plug in the head phones otherwise the tablet won't recognize that the head phones are plugged in.
5 REPLIES 5
SVWatt
Just checked mine. Doesnt matter whether headphones in first, or music playing first. Mine works correct.
MHitson
Ive tried two different head phones . What began as an intermittent problem is now a completely dead headphone port..
bigrana
I have same problem!!!  how much time for patch to fix this 4.2.2 problem!?
laurens
Having the same problem here. Nothing works to get the headphone jack working. When is there a fix for this because this is annoying!
laurens
Found a temporaly work-around for this issue. Just download this app and place their widget on your homescreen:
https://play.google.com/store/apps/details?id=com.woodslink.android.wiredheadphoneroutingfix
Everytime you need the headphone,  you can switch it on and off with this widget.
