Problem downloading Java applications to my W205
Hi, I cannot download java applications to my SE W205. Can anyone tell what can do to eliminate this problem as I regularly use an IM called Mxit here in South Africa to keep in touch with family and friends? Help to get this problem sorted out asap will be much apprciated
3 REPLIES 3
Dr_Chris
Champion
What you can try is to download the Java applications to your PC (from websites such as Getjar.com) and transfer the .jar or .jad files to your phone via USB, where you can install them.You can also run the software update service on your phone, if you're still having problems.
Thank you for your advice will try it as soon as I get the USB cable that I got with my SE K750i that I previously owned
Play around abit with my phone and managed to get at least Mxit V5.4.1 downloaded and its working. Only thing is I had to deactivate all certificates in order for it to work
