i cna't remember the phone lock code for my phone and now that i want to change it i can't
can anyone help me on this matter
Are you locked out of the phone at the moment?
No i just want to change the code and i cant remember it
Well, I suggest you perform a hard reset (Reset all) and this will hopefully re-set the phone lock code back to its default 0000.Remember to backup all the phone data on PC/PC suite/memory card/SIM card beforehand.Obviously, you need to keep the phone switched on until then, otherwise you will be locked out and you will need a service centre to unlock it.
i tried but it did not work
Then I suggest you take it to a service centre to reset the phone lock to its default.
do you know where the service center in madrid or spain is?
No, but you can ring the SE helpline and find out.
