Phone charging Problem
farazahmad56
Hello every one
I have Sony Xperia P. Whenever i connect the phone with data cable to my laptop it keep on cennecting and dosconnecting. some times very rare it works fine. but mostly i does not even charge the battery. i have tested it on many computers but same problem. Can anybody tell me how to solve this ??
7 REPLIES 7
Sam
Legend
Legend
Do you get connection problems when connecting to the wall charger?
RG08
I am facing a similar problem. It does not happen when my phone is connected to wall charger, but when i connect it wid my computer or laptop, it keeps on connecting and disconnecting.
farazahmad56
some time it does not start charging also when i plugged into wall socket. when i shutdown the phone and connect it with socket charger it start charging.
Please help me to solve this issue?
florenzgonzales
try using another USB cable,
farazahmad56
i have tried. i used HTC data cable and also Nokia's Original data cable but same problem. ??
any suggestions plz
profile.country.RO.title
_alexdon_
it could be from the phone microusb,it may be a little loose.have you charged it a lot or forced sometimes the charger in it?
alexdon
florenzgonzales
hard to say but maybe its a hardware problem dude particularly the usb port on your phone,im not really sure but the best thing is for you to go official sony center to look for any solutions on your problem
