Outgoing call problem !!
When I try to make call from call list then call goes to another number from bottom one.My touch is ok and it happens randomly. also after disconnectiong call a new call generates from handset without any touch or command.
can anyone help me...
4 REPLIES 4
Annie
My phone already updated 3 weeks ago. should I do it again..
Annie
Were you having this problem before the update? If so, it will not hurt to try it again at the link provided above. If issue persists, than we will look into other solutions.
am using this phone almost 1 month.After purchasing the phone I used 1-2 days and didnot find that issue. After update from android 1.6to 2.1 it becomes good.The problem started after 1-2 days of updating...Also handset seems quite slow while making any calls.....
Message was edited by: rezvhe
