Memory card problem
Memory card problem
Good day
1. Sorry my english
2. Mine W880i does not see memory stick micro m2, I have bought new. I insert it, but the telephone requires a code of blocking. I do not know it. I can not find answers on forums of support. Please, help.
19 REPLIES 19
Dr_Chris
Champion
Try formatting the card on a PC using a USB card reader and see if that helps.
Sorry, I have no card reader, only PC. The dispatcher of files does not show me contents of the telephone, only empty folder.
How it is possible to learn(find out) a code of blocking?
slimshaddy
Hero
just conect your phone to your pc in memory card mode..
an icon will appear in MY computer..
right click on that and click on format..
I get it, but folder is empty
Dr_Chris
Champion
I can't actually read the attachment but try formatting the card anyway, irrespective of whether the folder is empty.New cards often need to be formatted to get rid of any bugs and since they haven't yet been used, they will of course be empty.
I agree. But how to format a card, if is not present card reader, and PC the telephone through USB does not see
I believed here it is possible to find a code of blocking memory card, probably, code uniform to all telephones W880i
Dr_Chris
Champion
Well you could try using the default SE phone lock code 0000 (or add more zeros if it allows more digits), but failing that, I suggest that you try a different memory card and/or try this one in a different phone.If you think it's a software problem with the phone not recognising the card, then run the SE update service on it and/or perform a master reset, and see if that helps.If none of these actions solve the problem, take the card back to the seller and ask for a replacement.
Thank you very much, i'll try it
Dr_Chris
Champion
No problem.I've just been reading on the subject of memory card passwords and it turns out that a lot of people face this problem following a software update on the phone.Apparently, software updates can sometimes delete a file in the phone that recognises the memory card, but there are no known solutions to this, because, as you also found, the card is not even recognised by the PC to be able to format it.It is also thought that these cards are faulty and the only solution is to replace them.Let me know how you get on.
