Memory card problem hangs up
i bought a new x10 mini pro.. it comes with 2gb card... i used it for sometime.. it was just awesome.. then i thougt of upgrading it.. i bought a 8gb micro sdhc card... i started using it.. and from the first day.. it made my phone heavy... it restarts... hangs up.. screen times out.. nothing is visible i click photos they are shown corrupted in the album... i went to the service center they asked for updation of software and charged me also... but it also didn't work up... i restored my phone to facotry settings.. and formatted the card too... when i used the same card with some other phone it was good enough.. it just hangs up my phone.. while listening to the music also it stops working the phone restarts..
reply as soon as possible
thanking you
Gaurang Rastogi
3 REPLIES 3
you could backup your SDcard files and then reformat it and see if thats the issue, if you still have the 2GB sdcard try it and see if you get the same problems
i did formatted the mmc thrice.. bt the problem continues... and i've lost that 2gb card... any suggestion.. ??  Neutral_Face
backup everything and repair your firmware with Update Service or PC Companion
