Since maintenance update 1.1.a.0.1 my Xperia z3 compact is hot and the battery is draining fast.
I have had the same issue for a few days. The battery life changed from 1.5 days tot barely half a day. Yesterday I did a backup and factory reset and it seems to work. Now I got a notification to update again, not going to do that yet..
The only "solution" offered by Xperia Support is to Recover Software by using Campanion. The worst result!!
i have found a solution. go to apps, memory, and deactivate updates, it will come back to 1.0 version.
but now, the upgrade ask to 1.1. version has gone away, i don't find it more.
my case is i keep getting Could not install error message from both What's New and software update. attached.
anyone got idea why like that ? Just updated the system to 32.2.A.0.253 (Z5).
