Low battery Light effect
CoolToGo
When my phone below 15% battery, the LED RED light effect appear which cause more battery going to be use up quickly. Can I turn off the light effect when the battery is below 15%. Also can I turn off the light effect (Green) when the phone is  charging.
3 REPLIES 3
You can not turn it off
Danial-mach1
Leader
for that you must turn off light effect in setting>display>light effects...that will turn all the lights off...you cant turn off low batery,charging,and fully charged lights separatly
teherje
Makes me laugh that to notify you that you battery it's about to pack in they add a flashing LED just to help it drain that little bit faster. Completely foolish specification.
