lag problem
Mwai_97
lag problem
I got some question.Why my sony xperia J play templer run 2 and subway surf ,it is lag during the game process,how can i solve this problem??
5 REPLIES 5
dragpyre
You can turn the graphical details down in Temple Run 2 in the settings menu.
As for other games, ensure that you don't have a lot of background processes running (note RUNNING, not cached) during play.
Personally, unless you're sideloading APKs, an AV is useless and just a resource hog.
Dhimant_Rocks
Hi All My SAD Brothers,
Here is the solution to you problems:
100000 % Works
Just Install the below APK File (Calibrate.apk) by downloading it. Once installed just restart your phone.
Just Click on the below link:
http://forum.xda-developers.com/attachment.php?attachmentid=1595030&d=1356590148
OR
just point your Mobile Browser to the below Location:
Do Like if it solves your problem.
-Collen-
hey Dhimant
I downloaded the app but I can't press the "install" button, it doesn't work. Please I'm desperate for this because I'm close to hating my Xperia J-
-Collen-
okay I got it to work but it's still not as smooth as I would want it to be-
burosko
Thanks for help Slightly_smiling_Face It works!
