Higher Capacity Replacement Battery for XPERIA P ??
mithun_xperiap
Some one please check out this like is it possible to replace our device's stock battery with this 1500mah battery !! if possible then would be of great help.
http://www.batteryupgrade.com/shopBrowser.php?hideProducts=true#/assortmentProductId/93188393/shopGr...
9 REPLIES 9
beeelkuuun
I hope that's True! after I used my Warranty for fixing the damage on my Xperia , I'm willing to buy a battery higher than 1300mah, or a battery back up cover similar to those iPhone's
casimirfunk
Woah! o.O For real? Hehe so far my battery is good for me, no need to replace it with higher capacity. We'll try it when into rooting experiment! Slightly_smiling_Face
casimirfunk
beeelkuuun
yeah mine too! , but Imagine if we Put a 1500mah, it might get even better even at Hard usage of our device.
profile.country.RO.title
_alexdon_
It would be something,but it is hard to believe,because we were told it is a Li-Ion non-removable battery...
alexdon
Miltos95
It's not "removable" for the typical user. If you unscrew the phone you'll see that you can take it off in no time...
http://www.youtube.com/watch?v=4Sv_m2E50RY&t=39
_alexdon_
of course,it is obvious my friend.if the battery could not be removed anyhow,than how could they replace a faulty one?i said it is non removable for us...but at a sony center it is ok.
alexdon
coolprateek77
Instead of going for unknown low quality battery, you can use portable mobile charger like this one..
http://www.naaptol.com/mobile-chargers/sony-usb-portable-power-charger-cp-els-(white)/P/12176641.htm...
mithun_xperiap
i know portable charger is an option but i dont want that ugly thing connected to my device and moreover i just want a higher capacity battery so that i can charge my device and use it for atleast a day of medium usage. next sony will say is carry ur own car battery to make xperia P run more or always stay close to a wall socket :smileylaugh::smileysilly::smileysilly::smileylaugh:. Just Give us a  powerful battery Fuckers !!!
Xperia P is a great device but the low battery has made it a big fail. (Sad but true)
