Help!!!I am getting charged daily for something and not sing anything! It maybe to do with,I have been told,Google!How do I stop this!If I take my sim car out,I can of course se everything,bar make and receive texts and calls!
maybe it can help you... try to set "data traffic" off:
Settings> Wireless > Cell (APN ...) > tick "Data traffic".
By this you will turn off the service of data exchange from your cell provider, which may be not free of charge at all.
Along with this, there is a possibility of setting some applications in the phone not to update automatically - it is done, as far as I remember, through Application manager.
If you are referring to the data traffic (gprs), you can actually request your Carrier to cancel that service if you do not require it at all (can't you?).
