help?
help?
I updated my mini pro to 2.1 and I'm unable to use twitter via timescape how do I sort this?
2 REPLIES 2
Go to Timescape -> Press Menu (hard key) -> select Settings
Are you able to see Twitter, Facebook, Messages, Missed calls?
Check the Twitter box, you will asked to login to twitter. Then give Done.
Then refresh the Timescape content using the refresh icon (bottom right corner).
