Data re-enable does not work
I use to enable-disable the data  traffic on 3G connection. Usually the first enable after the phone boot works fine.
But if I disable the data traffic and I try to re-enable it after some time (let's say 30 minutes) it never connects again.
I have always to switch off-on the phone.
Any idea?
Thank you for all your comments...
