Camera and Memory Card problem
I've had my Aino since it came out and has worked perfectly fine. Just recently things have gone wrong, firstly the Camera/Video Camera won't save pictures and when it tries recording it just freezes and hangs up, secondly the capturing buttons have somehow been messed up, I now have to press the volume UP button then press the Camera button to capture but its useless since it wont capture anything. I've done a software reset on the phone and I get the same problem each time. I checked with the memory card and it keeps saying Empty Folder when clearly it has stuff in there. Can anyone please help me out with this one, I really need to get it fixed. :9
Irfy.
4 REPLIES 4
Dr_Chris
Champion
Try formatting the memory card and/or a master reset.
Tried that still does the same thing. Camera software or the memory card must be corrupt somewhere.
Dr_Chris
Champion
You can also try phone repair via PC suite.
Try to format the card from your phone (not from pc), or try to format it from another working Aino.
If that doesn't help I recommend on phone repair via pc suite, as Dr_Chris suggested (just don't forget to backup all phone content before doing that).
