Hello
can you tell me which cable do I need to watch on TV
Here you go
http://www.sonymobile.com/global-en/products/accessories/mhl-to-hdmi-adapter-im750/
Don't forget to give Kudos
You can also share content without a cable
Where can I buy the cable ? is it available in Canada ?
I went to the Sony store, I bought the cable but it doesn't work
What do you mean it doesn't work?
No picture on TV but maybe the tv is not compatible MHL ??
Well you mean HDMI compatible? if your tv got hdmi then it works, just switch on your TV remote.
