C905 Wireless Issues
Hey all, I have a SE C905 phone and am very happy with it. However, over the last few days, it seems to have developed a mind of its own with regards to connecting to my wireless internet at home. I have had no issues with this at all up until last week. Now for some bizarre reason, it doesn't want to connect for the most part. Sometimes it will be will then disconnect for no reason. Mostly, it sits there saying "searching..." or returns a message to say "no network found". I have just re-installed the software (I was already using the most up to date version available) which has made no difference.
Does anyone have any bright ideas as to what is wrong?
Thanks in advance.
3 REPLIES 3
Josh
Have you tried connecting to a different WIFI netowrk? if so does it do the same?
Hey Josh, no, I haven't tried connecting to another network as yet although I can tell you its not an internet or wireless issue here as I am connecting as normal via my pc. Nothing has changed with hardware or software either so as far as I can see the issue must be with my phone Slightly_frowning_Face
Johan
Master
In that case you could try to do a master reset on the phone.
Menu > Settings > General > Master reset > Reset all
(But I still think you should try with another connection as well, just to be sure)
