C905 wifi does not work
I have downloaded the latest software for c905 and updated it. My orginal problem still persists; When I perform a search for a wifi network (being next to a working wifi router) nothing happens, the phone can not find a single network.
The mac address of the phone is 00-00-00-00-00-00
Any ideas?
Elias
http://emergent-hive.com
Dr_Chris
Champion
The Mac address should be a hexadecimal series of letters and numbers, but not zeros.This is likely to be a hardware problem as I discovered when my phone exhibited the same symptoms as you describe.However, in order to exclude any software issues that may be causing this, you can try phone repair via PC suite and failing this a Master reset (Reset all option).You can also try re-installing the software with SEUS.Let me know the result.
