Bluetooth - A Definitive Answer Mini/Mini Pro
suze
Leader
I am often on this forum (and a couple of others) trying to help people with their queries with their new phones.  Now I am asking for your help.  Can you please confirm whether you can receive files on your phones via bluetooth.
It appears that once you have the app Bluetooth file transfer, you can in fact transfer from your phone.
I also understand that you can use your device to 'look' at the other persons device.... Is that the case and if it is can you then copy a file over eg access their media files and pull across a photo?
On the big X10's the system seems to work fine both ways so I don't want to keep saying to Mini users that yes you can if in fact no-one can confirm to me that they have been able to receive on the phone.  It would make sense of so many people having problems with it.
Thank you for your replies.  If we can clear it up then I can go back to giving good concise advice and not leading people with mini's up the garden path.
21 REPLIES 21
I am using SonyEricsson W8 Walkman running Andriod 2.1. My problem here is I cannot send file from my PC to my phone. The message show "No services found".
It is possible if I send file from my phone to another phone and vice versa.
If you any solution, please help me.
Please help!!!
I can only send files from my mini pro but cannot receive any files. As soon as i enter Bluetooth File transfer i get a caution saying "you do not have root permission". So what should i do to get this root permission?
