battery
battery
are the battery apps any good??? it says my battery needs an update,ive downloaded a battery doubler any1 know about this and other apps?
11 REPLIES 11
you don't quite need the app, if you want to have a better battery life just:
turn off wifi, gps, bluetooth, sync/background data, lower the brightness and if you are not using 3G/H just turn it off
you can use Quick Settings to control all that
https://market.android.com/details?id=com.bwx.bequick&feature=search_result
hi,i have that app,ive already done all that,it still goes too damn quick
go to settings -> accounts & sync -> uncheck background data
how fast is too quick?
ive done that one now,i can charge my battery everyday,ive noticed a few times now that it will show its 100%,then it goes rown 1,then 2 % whist charging,i thought that was odd,surely if its charging and not in use this should not happen??
if you are charging your phone w/ your Computer and your are running other apps while it charges it might drain more battery than what its been recharged, if you are using the wall charger and that happens then backup everything and repair your phone w/ update service
http://www.sonyericsson.com/cws/support/mobilephones/downloads/subject/updateservice/xperiax10?cc=gb...
ok,thanx, i will try it and let u know Slightly_smiling_Face
just remember that you will have to re-install the launcher (its already on your SD card so it should be easier)
ok thans again
anytime
