I bought this phone like 10 days back and it is giving me pathetic battery backup. Although this phone has 2330 mAh batterybut still this phone is giving me very less battery backup. Please suggest me what to do?
You will have to elaborate a bit more about your battery life time and your battery stats so we can get a better understanding.
Also, check this topic first. It has some good information about battery life time, how it works, how to improve it and what to expect.
http://talk.sonymobile.com/t5/FAQ/Battery-time-and-enhancement-features/m-p/347874#U347874
When i charge it full i.e 100% in like 3-4 minutes if use the device it comes to 98 % .....is it normal?
I wouldn't use that as an indicator.
Go to Settings, select Power management and the next screen will give you an estimated life.
If you don't like that number go to the very bottom of the screen and select Battery Usage and it will tell you where it is going.
I have Stanima OFF
Low Battery and Location Base WiFi ON
I also only turn on Locationing when necesary.
Right now at 99% mine says 3 days 13 hours.
I don't do music, but I do do audible books. Other than that I use it pretty liberally.
Good luck
