I got this beast just 2 days back and facing charging issue, i have tried changing the cables plugs switches everthing but still its not charging completely even after 3-4 hours. Help me out to solve this issue....
You're charging via PC or power sockets?
Try discharging your batter to zero, then charge it over night.
Whenever you get a new phone or reinstall/flash your phone, you need to discharge yor battery to zero and do a full charge a few times to get maximum battery performance. Because android will do its own battery calibration. Just repeat this a for a few days and it should be fine.
If not, u will have to return your phone for service. Somethign could be wrong with the battery.
I am from Vietnam and I also experience the same problem. I just recently bought a Sony Xperia Z and it can not be charged if it were turned off: No LED light, the adapter is not hot. Everything is fine when the phone is on, it means that usb cable and adapter did work. I will contact with Sony Customer Service tomorrow. So bad :smileysad:.
I think this is a known bug - for now just make sure you don't go completely flat and keep the phone on for charging
I tried by restarting and it worked, yesterday night it was charged full and even now 38% is left. Even heating is also reduced.
I do know about the limitations so i will be keep checking every half hour. Can you let me know how to connect wifi hotspot to my Sony Bravia LED I tried with an usb wifi adaptor but TV failed to recognize the device.
