Recently bought Xperia J's battery isn't charging. Can't figure out what the problem is, have tried both ways of charging, using the USB cable and Adapter. The battery isn't going above 9-8 % of charging.
I suggest that you try using another wall charger, if it still won't charge you should contact your local support team to have the phone examined and fixed at a repair center.
http://www.sonymobile.com/global-en/support/contact-us/contact-info/
