Hi everyone.
I am trying to pair my laptop to my phone (SE W610i). In fact, I paired them, however, I can connect via BT to my phone, but can never connect to laptop (get "BT connection problem" message). Though at the time I pair them I can connect to laptop and even use some services, any other times connection fails. PC Suite did not help.
Is there any way to connect from phone to PC via BT not pairing them again and again? Or how do I customize connection to control computer from my phone?
Also make sure that in your phone, you set the BT connection to the PC to Always allow (from Options), if you have this option.
It is always allowed. Unchecking services did not help. When I choose my PC in "my devices" and press "connect" I get message about failed connection. Or is the remote control switched on from elsewhere?
Not unless you have a direct Remote control connection under the Entertainment menu of the phone, such as some phones have, eg the W995.What you can do is assign a COM port number on your PC, to configure a Quick connect option to your phone.
Ah, should have asked where to switch it on in first post... I've never used the "Entertainment" tab before. Thanks a lot for help, it works
No problem.
