abnormal battery drain
amfirbek92
23 REPLIES 23
amfirbek92
I dont know what's happening with my device the last week..battery is draining so fast..my phone used to stay 1 day 12hours + with similar usage..now it's staying 12hours! And now i was shocked when i saw my battery draining from 50% to 39% within 8mins
It's true i have lifelog running but it's just collecting applications and SWR10 activities..anything other is off
Any help?
profile.country.RO.title
_alexdon_
I suggest you try safe mode,see how it goes:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
alexdon
amfirbek92
Thanks..will try it tmrw
ATM i'm charging the battery..i will keep it until i wake up on the charger and will use the phone without stamina..bcz i guess it's kind of fault related to stamina,software or rare battery fault..i hope so..not a severe problem and i hope i can get back my old battery life..the one i experienced the first 2 months with my z2
Also sony should give an interest on improving z2..the release of z3 just threw z2 owners far behind..also z3 got too much new software features which can all be easily present for z2 in upcoming updates..what i hope so
amfirbek92
Same problem persists today..i hope a near update will fix my problem and my battery isnt dead on this cycle ( 50%-39%)..
Sam
Legend
Legend
@amfirbek92 - Have you checked which applications are using the battery the most: Main Menu > Settings > Power Management > Battery Usage.
What are your thoughts about this forum? Let us know by doing this short survey.
amfirbek92
For sure i did..nothing, the problem is not related to a third party application for sure..nothing can drop the battery from 50 to 39 in just seconds
amfirbek92
Again and again..the problem persists on the same cycle, battery falls in seconds..and this time the phone was on sleep..that's really irritatingsketch-1410811655813.jpg
Sam
Legend
Legend
Please do check the area I have advised you off and provide the details of the apps there, it doesnt just show third party apps.
amfirbek92
Something is not accurate in the area u provided me to check..have a look
Yesterday morning i used runtastic bike for 2hours..once got home..i stopped the session and turned location off..up to now battery usage still showing gps is on while battery is draining normally
Another bugs i'm facing..call and notifications sound randomly gets low especially after unplugging the charger and u cannot choose scenes in manual mode in camera (scene button is always grey)Screenshot_2014-09-16-14-22-24.jpg
Screenshot_2014-09-16-14-08-41.pngScreenshot_2014-09-16-14-08-55.pngScreenshot_2014-09-16-14-09-09.png
