Здравствуйте неделю назад приобрёл телефон Xperia XA1 Plus, проблема с сенсором и заключается в том что сенсор к примеру по середине вверху или внизу работает идеально, а вот по боковым краям надо немного сильнее нажать, чтобы заработал сенсор, то есть если просто прикосаться по граням очень аккуратно и легко то не реагирует, стоит плёнка но она обычная и не по размеру телефона, меньше дисплея, хотел бы уточнить это особенность сони или это дефект?
Hello a week ago I got a phone Xperia XA1 Plus, the problem with the sensor is that the sensor for example in the middle of the top or bottom works perfectly, but on the side edges you need to press a little harder to make the sensor work, that is if you simply touch the edges very neatly and easily it does not react, there is a film but it is usual and not on the size of the phone, less display, I would like to clarify this feature of Sony or is it a defect?
GT
Boa tarde!
Comprei um aparelho Xperia xa1, onde o mesmo pela segunda vez apresentou defeito.
Defeito esse que não consigo acessar a barra de notificação, os cantos da tela amarelados e a tela acendendo e apagando.
Foi enviado para garantia porém estou no prejuízo com o produto da sony, paguei tão caro no aparelho em três meses o aparelho foi para garantia duas vezes, e com isso fiquei sem aparelho tive gastos com películas e a Sony irá mim ressarcir esses gastos gostaria de uma resposta da sony comprei o aparelho porque preciso usá-lo e não deixa na garantia. Ordem de serviço. 120944 e 125870
Att.FLORISVALDO
Good afternoon!
I bought a Xperia xa1 device, where the same for the second time was defective.
I can not access the notification bar, the yellowed corners of the screen and the screen on and off.
It was sent for warranty but I am at the loss with sony product, I paid so expensive in the device in three months the device was for warranty twice, and with that I was without device had expenses with films and Sony will reimburse me these expenses would like to a sony response I bought the device because I need to use it and it does not leave the warranty. Order of Service. 120944 and 125870
Att.FLORISVALDO
GT
