Hola ,estoy intentando utilizar mi xa2 como todos mis demás teléfonos ,para pago con nfc,pero me resulta imposible.
La transferencia de archivos si funciona ,pero el pago ,no.
He utilizado tres aplicaciones diferentes,pero es como si no existiera el nfc al acercarlo a los lectores.
Como digo,si lo acerco a otro teléfono con nfc lo detecta perfectamente.
Hello, I am trying to use my xa2 like all my other phones, for payment with nfc, but I find it impossible.
File transfer does work, but payment doesn't.
I have used three different applications, but it is as if the nfc does not exist when bringing it closer to the readers.
As I say, if I bring it to another phone with nfc it detects it perfectly.
gt
hello @Lufelepe
have you checked if the apps have the right permissions eanbled for nfc use? try to check by going to settings>apps.
also check the in app settings that might need to be enabled...
