Hello, unfortunately, my Xa1 came into contact with a large amount of water. I turned it off and put it in silica gel. 10 mins later I turned it on and found it was working however it abruptly turned off once and continued to do so. I turned it off again. What should I do?
Hi
I dropped my phone too! but actually it was fine, after the accident I put it in rice.
The only thing that goes wrong now is that the battery dont last like it did before, probably I will go to the tech.
