Double tap to wake
Hariyanto
Double tap to wake
Is the xperia xa1 ultra support double tap to wake? Thx
-Sorry for my bad english
@Hariyanto
I got good news and bad news, double tap to wake up it is not available with this Xperia
BUT
There's an option to tap to sleep
home screen > long press on any empty space > settings > Double tap to sleep
16 REPLIES 16
@Hariyanto
I don't think so but I'll try to get more info on this
@Hariyanto
BUT
EdsRf
When will it be possible to unlock with a double tap?
Archiehobbie
Surprised that this function is not available. Surely it should be implemented soon.
Hariyanto
Thanks for your answer,
But can you tell me, the xperia ( which dont have the fingerprint sensor) get this feature like xperia XA, XA1, XA ultra, XA1 ultra or any other series?
Thanks,
Rye002
Why Sony does not install tap to open in other units? is the same sony Expressionless_Face
Zuhairfattal
I have sony xperia xz premium i want enable double tap to wake please
LevsMAN
Double tap to wake device is available in quite a few Xperia's as I once owned a Z2 on 6.0.1 software (which I still think that's the latest build) and that had double tap to wake.
Also, I still own an Xperia X and this has the double tap to wake on 7.1.1 👍
I was thinking to myself as to why this doesn't have support for double tap to wake, and I'd like to point out Battery Care within Settings -> Battery.
I'd like to also point out that BOTH devices have the same build of Battery Care.
I have attached 2 screenshots, slightly off topic but it's out there...Xperia XA1 Ultra (Android 7.0)Xperia XA1 Ultra (Android 7.0)
Xperia X (Android 7.1.1)Xperia X (Android 7.1.1)
BeeM
How to activate Double Tap to WAKE screen.
