Hi
I am useing Xperia X f5122 stock rom not rooted bootloader locked i mean original
My gyroscope in every level/bubble apps on any flat surface show me 4°degree insted of 0°degree.
I did reset, factory..., Sony pc online upgrade and repair, also without my cover testing, and use some apps for calibration ...
But i got No results for that.
Some apps they have initial calibration and some apps they don't. But every time i must to use this apps after calibrate again.
I think we need a calibration setting for gyroscope in sony devices.
Also not all apps have gyro-calibration
Thus picture shows my problem(its not for Ad)
Ps, excuse for On flat surface
On flat level
You did use the support app to test as well?
The support app on your phone has many tests.
If I may ask:
Why is it so important that it is exactly calibrated?
Thanks for answering my post.
As you said, I checked the support and did all tests.Actually the gyroscope sensor passed that test. Also i checked service menu tests and all things has worked good.
But my calibraty has wrong about 4 degree in all apps.
Um. I am glad to have comunication with yours 🙂. It's important, because:;
- I use my phone as leveler a lot 🖌️👷
- I like so simple apps☕
- a little The true calibration is related to my calmness ☺️.
You know why I ask about calibration?
If I have 3 different temp/hum sensors on my desk they all show different readings, that is to say, different translations from the actual temp and humidity.
Same goes for blood samples from let's say cholesterol.
See the results as a rough indication, nothing more.
It points to the truth.
Timelines then can give you an indication of change, which is more important than the exact figures.
For your leveler you might go to a camping shop and buy a leveler there.
Choose amongst 5 or more to see which one is closest to the average.
This error is more than just wanting to compare it with ordinary accuracy
I uploaded a video on youtube to say my mean, because of my bad english 🙇
