wi-fi connection problems
Gabes2973
Is anyone having wi-fi connection drop outs scince the ics update , I never had a problem beforehand but now I keep having to reset the wi-fi , and the tablet seems to struggle to pick up a signal.
I know its not the router itself as all other devices are running fine.
any fixes would be much appreciated .
3 REPLIES 3
gaarbon
I'm having the same problem since ICS, the tablet now also drops the wi-fi connection completely when
it sleeps on the cradle even though it's set to stay connected.
Gabes2973
seems as if the auto connect is failing.
mpattenden
There is a free app on the store called Advanced Wi-fi Lock - should fix any issues you are experiencing. A workaround not a fix but free and should work.
HTH
Regards
Padster
