HELP - Xperia Z4 in endless boot mode (Sony blue waves)
Stephan_M
I wanted to install the Blackberry Enterprise Solutions according to our IT-department. I did all the work, however, the BES Work Manager didn't open. After restarting my device, it doesn't work anymore.
I am in an endless "booting" mode, the blue waves of Sony... I tried a hard reset with on/off button and volume up. It shuts down the tablet, but when starting I get the same blue endless waves...
Can anyone help me? I am also willing to do a factory reset, but all my google search didn't work. (I cannot get into recovery mode by clicking volume up/ down when starting new).
Slightly_frowning_Face
Thanks, Stephan
Thommo
You need to perform a system repair using PC Companion - This will factory reset your phone and erase all data which is something you can't evade unfortunately
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the on screen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
2 REPLIES 2
Thommo
Stephan_M
Thank you!!! Slightly_smiling_Face
