Sony WH-1000XM3 quick mute
Uberbres
I've recently bought the Sony WH-1000XM3 and was expecting there to be a quick mute function on the headphones rather than having to go to the laptop or phone application and mute within that. I'm very disappointed that there isn't!
I have a cheap headset on my office PC that has a physical button on the headset which I regularly use and is very convenient when in conference call and there is noise in the background that otherwise gets picked up by the mic.
Surely this is a function Sony can add into this headset!
11 REPLIES 11
Anonymous
Hi there,
Thanks for your feedback. I'll pass it on.
Best wishes,
M
Uberbres
@Anonymous Did you pass this message on and did you get a response? If so what was the response and is their any progress on a getting this feature added?
Win_88
Specialist
Hi @Uberbres
I know the headphones have a Quick Attention Mode which can be used by covering the right touch panel:
https://helpguide.sony.net/mdr/wh1000xm3/v1/en/contents/TP0001703150.html
You can also pause playback with the touch functionality:
https://helpguide.sony.net/mdr/wh1000xm3/v1/en/contents/TP0001703116.html
This works the same way as play/pause buttons on other headphones. The functionality depends on the Bluetooth profiles supported by the connected device.
Win_88
profile.country.AE.title
Clee23
Hello Sony!
When can we escpect the very basic feature?
Still cannot believe, that after spending >200€ for Wireless Headphones, i cannot mute the micro in calls. This is very basic and easy to implement. When can we excpect an firmware update?
Kind regards,
Clemens
Win_88
Specialist
@Clee23 not sure if this will be added, but I sent your feedback to Sony via their contact page.
Uberbres
That function doesn't mute the microphone
Uberbres
@Win_88 I meant to say Quick Attention Mode doesn't mute the microphone
Win_88
Specialist
@Uberbres yeah that true. Muting needs to be done using the connected device.
brunojohnson
I completely agree, a quick mute hand gesture is necessary. When used as a headphone for any time of call, a mute function on the headphone itself is essential. Can this please be introduced by firmware update?
