sony wf-1000xm4 wireless earbuds replacement charging case
profile.country.IE.title
LiamTwo
is it possible to get a sony wf-1000xm4 wireless earbuds replacement charging case? If so where?
Thanks!
Liam
6 REPLIES 6
Griffin_door
Specialist
LiamTwo
Would you have the product code of the case?
HannahEd01
@LiamTwo, only Sony reps has the part number. I will contact them for you.
TinyDragon
It says “you can buy the case from
the third party” I’ve researched the internet and nobody seems to have the replacement charging case. Did you find a replacement @LiamTwo ?
TinyDragon
I’ve lost mine last week but Sony support website doesn’t link any suppliers. Any chance to purchase it directly from Sony? Is there any way to get the replacement?
thomas94
just search in Google
(sony A5036917A)
this is the correct charging case you need.
