Hi-MD Walkman MZ-RH910 works perfectly (old machine) , but how can i use on windows 7 or 10? The web
profile.country.BE.title
jodierckx1
Hi-MD Walkman MZ-RH910 works perfectly (old machine) , but how can i use on windows 7 or 10? The website tells me there is no support anymore for sonic stage for windows 7 and 10. I believe i do not have the right driver.  Is there no other way i can put my music on the computer? Too stupid because the machine is ok..
3 REPLIES 3
Sean_Mc
Moderator
Hi Jodie,
I'm looking into this for you and will update the thread when I have more information for you.
Best wishes,
Sean Mc
Win_88
Specialist
Hi jodierckx1,
Since there aren't drivers for the Walkman for newer operating systems, there isn't much that can be done outside from some drastic actions like actually installing windows 2000 or 98
Win_88
Sonyvores
it's been answered many times just use search function or google it and you'll find your answer
