CFD-E100L (Radio Cassette CD Player)
Dibicie
Anyone know how to fix a 'no sound' issue with this product, please? Picks radio stations, plays CDs and Cassettes but no sound. Only slight sound heard is when it is switched on or off. Many thanks.
3 REPLIES 3
Anonymous
Hi there
Assuming that it is a hardware fault, you may want to either consider the following;
  • Take the CFD-E100L to a repair shop for diagnosis and repair
  • It might be more cost effective to purchase another radio/CD Player
I have attached the service manual to this post (PDF) - however I advise caution if you do not know what you are doing.  At your risk.
Dibicie
Thanks a million. Will try Sony Service in the UK again as previously they said they couldn't help as they didn't have the service manual for this device.
Regards.
Anonymous
You're Welcome :slight_smile:
