an old but still well loved walkman
Catalexjack
Hi ... I have the HW-HD3 Network walkman with SonicStage. I can no longer access the online music collection I had with this but still use the walkman (the CD to load again is very old (2005 for XP). The next prob i have is the wires on the charger are become more exposed and charging requires a bit of fiddling around with this. Do you think i could still purchase a new charger and/or get my online library up and running again.(the Walkman has quite a collection of music, a language course and other audio files, I'd be sorry to lose these. Any suggestions?  Catalexjack
3 REPLIES 3
Marino.Manolo
Marino.Manolo
If you have the adapter to connect the power cord you might think of buying one, even if not original, but having the same plug is the same polarity (in addition to the same voltage of course). You should have all the information on the current power supply.
Manolo
Catalexjack
thank you Marino ... will check out the link and suggestions.
