i am having a problem with my wireless conection, when my AR41 starts its fine, but after a minuet or so the light goes out and refuses to connect. my other wireless devces are fine. can anyone help i am gettin realy anoyed now.
Hi mad mik
Not sure if this will solve the problem but have you installed the Wireless Switch Utility 3.6.01.18210.?
If not then use either the VAIO Update Utility: double click on the Vaio Update icon in your system tray and follow the instructions.
Or
Use the following link then select your model in the drop down list to download the update: Wireless Switch Utility 3.6.01.18210
