Can anyone give me some advice on WLAN setup please ?
After I bought my VAIO in November, I used the 30 day trial of Web 'n Walk, but did not take out a contract with them because of the price.
I have recently gone for the 3 Broadband which is 3Gb a month for 18 months at £15 per month. This comes with a free Huawei dongle, and that all works fine.
However, I would like to run it using the VAIO's built in WLAN, as I did with the Web 'n Walk.
The T-Mobile Communications Centre will not allow me to use that software (not surprisingly I suppose), and I have failed to adapt the 3 USB Modem software to run from the machine, rather than the dongle.
I'm sure there must be a way of doing this, but have completely failed to date.
I would very much appreciate any help.
Thanks,
Jim
Hi Jim,
welcome to Club Vaio..
Does any of Blencogo's post in this thread help, use the following link to View the thread:WWAN Application
Hi Thalamus,
Thanks for the suggestion, and yes it was a great help.
I uninstalled the T-mobile software, and downloaded the Globetrotter Connect. It is working (which is great), but is not quite right somewhere along the line. On occasions it doesn't recognise the device, and I haven't worked out quite when or why this is going to happen. I think there are some conflicts with the previous settings which need to be resolved.
I worked out that in the WWAN connection utility section of the main VAIO smart network window, the application needed to be changed from the T-mobile file to
C:\Program Files\Option\GlobeTrotterConnect\GlobeTrotterConnect.exe
but if I click on the Activation button it is still taking me to the T-mobile 30 day offer screen. I can't see any way to change/delete that, and I don't know whether that is anything to do with it. If you know how this can be done, I would be interested to try and see if it makes any difference.
Many thanks for your help.
Jim.
