Wireless connection interrupted!
luis19martins
Hi!
I have been with a problem with my Vaio FS215S wireless connection. What happens is that it gets to slow, and sometimes interrupted to often, during browsing. When I play Call of Duty 2 online I have allways a lot of lag (999 ping a lot of times).
I have not allready upadated the "Wireless LAN Starter" and the "Intel Wireless LAN Driver" from Vaio Update. Can this be the cause of the problem?
Thanks for any help or sugestions.
Regards
Luís Martins
danreed
Luis,
Updating the drivers may help, but I suspect your problem is down to signal quality. Have a look in your task bar and see what your signal strengh says. If it's poor/Low this will be the cause of your problem.
Another thing to try is to try your laptop next to your Wireless Router / Hub and see if this is still a problem.
