vgn-bx195sp won't power up
soozle
A laptop at work has stopped powering up. When I press the "on" button nothing happens, I've held the button down for 10 seconds still nothing. Swapped the battery with a working laptop - nothing. I've removed the RAM, HDD and optical drive and tried again, nothing. Tried it on mains with and without battery - nothing.
Is there anything else I can try? It's just out of warranty.
At the moment the battery charging light is flashin but that's it.
Thanks for any help
Su
Thalamus.
Champion
Hi suarmitage
Try, if you've not done so already, disconnecting the ac-power, remove the battery and press and hold the power button for a minute to discharge any remaining electric charge, then reconnect the power supply and try to start your vaio..
If that does not help, then either contact Sony for a repair, or, you could see if a local PC repairer in your are can repair it for you. Make sure you get a quote first though.. :wink:
